Hi just a curiosity about motor. Sounds like a bad idea but example let’s say u got 2 motors.
1: maytech 6374
2: Tb 6374
(Just picked 2 popular brand)
Will they work well together if u program ur Vesc settings the same.?
And is it a god idea to pair a brand new motor and a older one that gott a lot of miles but still working great?
Well when one of my primary motors went bad earlier this year i used 2 of my spare motors until i got a new 6384.
The spares was a used enertion R-spec 6374 190kv and a new flipsky 6374 190kv, they worked great togheter, just make sure that all the values during detection are close to eachoter and it shouldnt be a problem
the thing to avoid is forcing one motor to spin faster than it’s no load speed - because if you do the motor above its no load speed will be generating more voltage (back emf voltage) than your battery and above a certain voltage it can damage your controller.
you want both wheels to go the same “virtual” ground speed at no load by adjusting the gear ratio if you use different kvs, to avoid producing higher voltage than your battery voltage from the motor which would be forced above its no load speed.
