If you select the tubeless options it changes to a picture with rims that have 5 bolts. Im definitely tempted
Might just be to hold the wheel pulleys on but who knows. Could have some funky beadlock type system where those bolts hold on an outer lip/trim that holds the tire in somehow (doubtful)
Maybe but the cyclone wheels have no bolts.
Does kind of look like what you said could be possible. Hopefully get more details soon.
I have a set of these in transit. Will report back once they arrive
Jesus those look wider than the landsurf RS tires?
How wide are they?
Fuuuuck they look awesome!
Wow those look so sick
Anybody want them? I got no use for belt stuff lol, these are for sure the widest tire I’ve seen yet
67mm wide
@Skyart Are they Trampa or mbs hole pattern?
I put an MBS hub over it and it’s close
Center to center on the bolts is about 48mm
Dang you can tell right away the benefit of no tube
Man no surprise there. I really wish tubless was as common as it is in cycling. I love my tubless mtn bike and road bike tires. Definitely a bit messy but fuck tubes.
Is tubeless better for free roll I don’t understand. Also, goddamn they’re wide lol. Interested in seeing if they’ll just offer the tires
Less unsprung weight and no bunching tubes. Helps with tire balance.
No not about freeroll, look at how true the tire is and that’s at 20psi lol
Ah ok.
Yeah the 20psi makes sense, that’s the main reason I run tubeless in MTB. For the low tire pressure
Shoot, how much lol
Also, for science - do you know if the landsurf RS tires would work on the tubeless hub?
