Rumor has it they come from the same factory as the new boosted stealth wheels. Which are “shit” but in the grand scheme not that bad. Most things seem shit when you compare them to Labeda thane.
While we’re on the topic. Boa has ONE product… how fucking hard can it be to take your profits from the first run and put them into another run? That was a trick question btw, the profits sunk into the deep dark pit of their fantasy skateboard company.
Just to be precise. The ABEC adapter has been made to fit both clone and original core . With other pulleys the wheels will only fit clone or original core adapter based on what core they use. Just look at the core and if they have large spoke then is clone or thin spoke for original.
Depends what you need the wheels for. Which Pulley you have ecc… To me 100mm wheels is better but like popoca quality, boa ecc… Otherwise the soft original ABEC are also good. I don’t know if it is just my impression but the kegel core seems smaller and therefore more urethane for same diameter wheels. Anyhow I tried quite some clone and they are day and night compare to popoca or now TB110mm. The latest are great wheels, a bit too big but they have been made for Esk8 purpose only.
