Well try getting the outer bearing race out and replace it, if you have calipers you can measure everything and find a replacement ez
got the bearing out
contacted maytech about size and pushed the bearing in and then the can wouldnt close. i tried a bunch of different things but none seemed to work to replace the bearing
no idea what size it should be and maytech dont seem to know its size either
Did you try scrolling a bit up?
its not the big bearing but the small one at the rear
maytech said its 15 x 10 x 4 but i bought those pressed all the way to as far as they can go and the stepped bit of the shaft wouldnt allow the can to go all the way
You can measure the thickness of the races too do determine.
Put inner, outer and thickness in twenty4bearings.nl and you will see results, you can round the sizes most of the times up to a .00
i cant measure the inside race sadly as i dont have that to use
Wdym, is there no inner race left? You can also measure the hub it was sitting on.
the inner race broke at some point and i never saw it
the motor shaft it sits on i cant see without removing it. i dont know how simple that is to do.
