I have a makerX DV6 pro that I’m using to replace a blown storm core. The only problem is that the power button is too tall for the enclosure. Are there any aftermarket ones that are shorter? Thanks!
Does the dv6 pro automatically turn on when you plug it into a battery without the button plugged in?
Yeah
After some reading I believe it’s a NC switch. How would I find a replacement that will work? I don’t wanna kill another VESC
It won’t kill the vesc if you used the wrong switch, it’ll just not work right.
Ok, so just look for a NC switch that fits the hole?
Yeah. May be hard to find. I think @frame found smthn.
Thank you!!!
