i’ve just finished my build but can’t get my Bluetooth Module to work. I already tried updating the Firmware of my VESC ( Maker X Go-FOC DVB6) and flipping TX and RX 100 times. Also i tried every kind of settings but when i try connecting the divice it timed out or showed me can’ load Firmware. These are my settings →
It’s hard to tell from the pictures, but it looks like you are plugging the BLE module’s TX/RX wires into the hall sensor port? (circled in red in your pic). I assume this is because you are trying to program it, and if you previously tried connecting it to the COMM port with all the right wiring, then here is how to properly connect it to the SWD port.
You will need to connect the 3.3v, GND, SWDIO and SWDCLK connections on the bluetooth module, to the same pins on the ESC for the SWD programming to work. That module only has 4 wires, so the SWD connections must be pads on the module somewhere that you can solder wires onto. Something like this:
Whoops marked the wrong port those are for the hall sensors. I connected the BT module to the port right next to the marked 1. But i will flash the dongle with another VESC where i dont have to remove the cover and after flashing the right firmware i’ll try to use it on this VESC. I’ll update when i finish flashing.
@YUTW123 Is this an known issue. Im not the only one who’s having trouble installing your dongel. You also dont have a download link for the firmware of this dongle just those of the VSEC.
RE-Download the firmware should solve the problem. It is recommended to use jlink downloader, if using VESCTOOL to download. You need to check “Verify during download”
