M Boards Nova 7 inch tires on Acedeck hubs
Happy Saturday, hope y’all are having a good weekend.
Will M Boards 175mm 7 inch tires fit on the Acedeck CNC hubs? The stock tires are 180mm x 65mm. These tires are 175mm x 50mm. I know the diameter is not an issue but I am worried that they are not wide enough.
I have the Nomad N3 gear drive.
Most probably You will need some ( for example ) 3D printed spacers which will reduce width from 65 to 50mm. It will looks not so much nice but it should works.
yes they’ll stretch just fine
If you still have any doubt, the guys at MBoards are very knowledgeable. Just call or chat with them and ask.
If it’s a tight fit, warm/hot soapy water and soft, rounded plastic ply bars.
