Lucian | Landyachtz Evo | 12s5p | 2wd 190Kv 6374 | FocBox Unity | ABEC 107 Superfly's
I see. I probably will tape it and then put some heatshrink over it, to prevent any disconnects. How is the unity treating you otherwise?
So far I haven’t had any unity related issues. I brought it up to 37mph but was getting wobbles cause my bushings are too soft. So nothing on its end killing me. I had help from @Winfly and @sofu to help set it up so it’s been pretty solid for the time that I could ride it.
Nice to hear! What diffrentiates the process they showed you from the normal “guided setup”?
Uuuh, to start Sofu doesn’t use the Focbox UI app, its like a more in depth one. But basically double checked to make sure all the voltages and cutoffs were correct. Also reduced the deadzone in my Hoyt so it’s more responsive now (previously I had to push about a centimeter for anything).
It’s basically the difference between reading the instructions and doing it yourself vs it being done for you by someone who actually knows what they are doing.
