Pretty easy thing but with normal single vesc you need to include a switch and battery meter and remote as you can’t use the meepo ones. They are specific to the esc. With a unity with its switch integrated its even easier. One thing to be aware of though is the standard battery has a very low output so the bms is rated accordingly. Don’t try pulling some high battery amps from it because the bms will pop. Ask me how I know…
Max you can safely draw is 20 per vesc. You can set the motor amps to 60 though and this will give you significantly more torque without them getting too hot. Run them any higher and they try to melt the thane off. Again ask me how I know…
I loved my little focpo it was a fun board. Guy I sold it to still rides it and its going strong. If I had known at the time that enertion were stopping the focbox I would have chucked some hk vescs in there but we live and learn.
