Looking for a wheel and pulley combo thatll fit these trucks. Im finding no results online and a question i already asked about these trucks with specific wheels went unanswered. Anyone able to help find wheels thatll fit these trucks? Especially on a 47mm long axle?
Looking for something that isnt that small. I cant ride wheels like that in my area. Roads arent good enough
Skill issue
Real, it is ohio after all😭
what deck are you using it on? that’s probably gonna be the other factor that will affect the answer
Please be Cincy area
Changing from TKP to RKP is likely to drastically reduce your wheel clearance
Nope, up in the falls
I mean. Im not switching. Theyre gunna get mounted the same
You showed a photo of TKP trucks on your board, and you linked in the OP a set of RKP trucks. That geometry change is likely to affect wheel clearance drastically.
They should still function the same. Its not like im gunna start grinding the side of my board on the pavement.
i mean you can grab some rims from mbs, pulleys are pretty easy to find in mbs pattern. boundmotor phantom hubs aren’t bad either, omni also sells them
