Looking for an enclosure to fit a 10s5p battery that’s 200mm wide for a vestarboard deck (It’s very similar to a bamboo GTX deck).
Checked with @Psychotiller and @BigBen and they didn’t have any that wide. It’s a weirdly built 10s5p
Even Bigly is “only” 190mm wide
I’d look into making a custom enclosure
What deck exactly are you using? I have some used TB enclosures that might work depending on deck.
Also, how are the cells arranged? Maybe reconfigure the cells if you can.
It’s a vestarboard blackhawk deck. Similar to evolves.
typically batteries are matched to the deck/enclosure, not the other way around. Top mounting is one way to get nearly any shape battery to work, but if it must be that battery and it must be bottom mounted, you’re looking at a custom enclosure. Kydex, fiberglass, or hunt around for some Tupperware that fits ![]()
Hmmm maybe I’ll do a pelican too mounted instead.
Hmmm, if shipping isn’t too bad, I might take you up on that.
Is this kydex ?
Negative. Its layed fiber glass. I tried using kydex a while back and really didn’t have much luck. Didn’t have a vacuum setup.
Nice thanks
I also tried kydex twice, and highly recommend fiberglass over it and ABS. Not carbon fiber.
Worst memory of the early DIY experience.
OG Junax caliber mounts. Destroyed 4 motors due to massive slippage in the mount. And kydex lol
80013
So mine was done with 2 12" pieces (working with what I had on hand) instead of a full piece. My corners looked no where near that good. And @ the time I didn’t have a good knowledge of how to bond the two together.
What deck was it designed for?
Hummie
