Hi Guys I’m looking for a 50.4V charger that does at least 3-4amp charging rate. I currently have one that does 2amps and it is not cutting it for me. The plug my bms uses is the 5.5x2.1. Thank you
@KaramQ was selling one
@KaramQ do you still have it?
Beat me to it lol
I have this charger. Shit slaps, and its super small for a 4A, definitely the smallest 4A out there.
Yes I do
Really does, realistic charge is actually 4.5a
But my charger lol, been waiting to be swooped by someone
Yep, can confirm that. I seen on my bt bms it was pushing like 4.4-4.5A weird.
I have 2 and the one I’ve been using has done 4.7 before lol. By far my favorite charger tho
I just brought the torque board one. Thanks guys!
I could have sold the same one for 40$ smh lmao
I can cancel !
Don’t do my man dex like that lmao, PayPal refund will take you 4 days
Actually, might be a 5.5A charger now. We upgrading.
Is 5.5amp safe for 12s5p with Samsung 30q cells
Definitely safe
5.5A ÷ 5p is 1.1A per cell, well below the standard charge rate of each cell, and no where near the fast charge limit of 4A per cell. You could use a 16A charger if you wanted and still be totally fine (though your BMS/charge port/wiring might have something to say about that lol)
For less than price of a charger you can grab a cheap bench power supply that does up to 5A.
Then you can use it for 1s thru 13 or 14s not to mention you can also charge your pack to 80 or 90% to length your battery pack life. Why buy dumb chargers anyways.
I personally only use bench power supply now, and usually trickle charger at night at 0.5amps which helps battery last much longer. And I can always fast charge at 6 amps if I wanted but fast charge kills your battery pack, I usually stick with 4 amps at most.
How can you connect this to a dc charge port?
