In need of a 12s BMS. Would be nice to use to discharge balance. But a cheap one would work as well.
Located in the USA
Located in the USA
discharge or active balance
Sorry, I mean discharge. My battery can do 100a. Either need a bms that can handle that or a cheap one for charging that I’d use with fuses.
Thanks,
the “100A”: smart BMS is pretty huge. There is the 80A discharge bestech bms that is slightly smaller but not 100A.
Most people do not trust any discharge BMS.
Good to know. Are you familiar with any cheaper bms that are located in the US? One that I’d use only for charging.
searched far and wide for ya buddy
Holy shit you saved me from an aneurism. Thank you very much!
what’s the balance trigger voltage on those?
Also, for not a lot more moola, you can get a smart BMS. Search 12s LLT and set it up bypass.
idkkkk… sounds quite tough.
