Linnpower EVO MK-1
Board is great, I have the belt drive.
Hobbywing controller is fine too…except when in the neutral position…board on and remote on and connected hands off the control…motors run slowly and board creeps forward.
It doesn’t happen when the board is cold…does happen after a few gentle miles…its annoying.
When I need to stop at an intersection the board throws an error code that the motors are stalled.
i have not messed with any settings or etc…I don’t even know where to look
I do need to send LinnPower a video of the problem…but was wondering if someone could help just solve the issue? If no I will post up what LinnPower offers as a solution.
Mike
Hobbywing controllers will throw that error (stalled motor) when the throttle is being hardly applied when at a stop, or trying to go up an incline etc. I was told it’s not really a problem and no cause for alarm (on a different board, a Backfire). As for the creeping throttle, that I’m not sure but maybe check your remote… sounds like the thumb wheel maybe isn’t returning back to the full neutral position
The stalled motor code is good…controller knows what is going on with the motors and current.
Thumb wheel is good from the mechanical side.
Are there user accessible settings on the Hobbywing?
:rofl::rofl::rofl:
Bad assumption? Or is this a disaster waiting to happen when the controller is pushed to the limits?
I don’t want to get negative with Linnpower’s boards they are great for the money and my use.
Not sure, depends on the model I’d guess. The one I’ve used is an older model so probably has different options than the newer versions.
