Limit Prebuild board to 6 kmh
oh yeah forgot to mention Onsra
The Nyx Z1 on 2WD, at merely 70 battery amps, is faster off the line than the 4WD Atlas Pro, which is supposedly on 140 battery amps but through my gauging the max I could bring it to is 120 Amps (I’m 220 lbs so yes I’m definitely pushing all the amps it could give)
Both boards have a top speed of around 60km/h, the Acedeck IS on a 14s system though, so under same top speed it should have more torque however it still doesn’t explain how a 4WD is getting out classed by a well built 2WD. My only guess rn is that if Exway were to implement traction control and better tires. On my Exway my front tires skid out every time I launch, honestly for a 220 pound rider it shouldn’t do this but credit to where credit’s due this board isn’t bad at all, Acedeck just “aced” it in terms of how the whole system is put together
The only ESCs from HW that offered consumer level motor calibration was 9028 and its Exway proprietary version that’s on the Atlas Pro and Flex Pro called 9042. All previous versions had to be pre programmed by either using motors HW manufactures or send them the motors you wanna use and let them write a specific firmware for that motor. This is also the case for almost every LingYi ESC
Yeah guys I found myself often pondering at this very same question recently, who tf are these guys :eyes:
