I can confirm 390 for 16/66, you might need 395 or 400. I ran 395 first with my setup, it runs, but too much slack, so now 390 with the motors not positioned at max distance.
This post makes me appreciate the Hoyt St Belt tension system, the MetroBoard X has that as well.
I LOVE ESK8!!!
You guys are fuck*n AWESOME !!!
the haggyboards belt drive is stupid easy too and has a sliding belt tensioner you can adjust with a hex key.
Thanks appreciate it.
Frit or gripe tape?
clear gloss polyurethane with clear glass. Its going to look like jolly rancher shatter when its done.
Have you ever used polycrylic?
For Science
No I’ve never tried acrylic. Does it crackle after a while?
I don’t know it’s just water-based not oil base I need to read up on my Frit threads going to try to glass myself
check your email. i have good news for you
May all your sprinkles be high and dainty. That’s how you acheive maximum entropy.
will check in a few. Up to my balls in poly and glass.
Making multiple of the same is the hardest to do
laying 40 inches of die cut permanent adhesive vinyl striping on a custom painted deck and getting it straight is enough to make me almost vomit from nerves. Doing it twice requires alcohol and weed.
Jesus that right one is nearly blinding I love it
