Has someone some LM3671MF-3.3/NOPB lying around?
I dont need to order anything else so shipping from supplier is just to much atm.
Maybe Iam lucky. thaaanks!!
Wasnt that part ditched on later VESC6 revisions because of the switching noise it injects on the analog rail?
dunno but it shorted on the escape vesc 6 from someone in the forum. Just have it here for repair
Do you have pin to pin comptabile 3.3V LDO? Dropping that in might work instead.
The inductor is effectively a short circuit at DC, you can bypass it as well anyway.
you mean like lg33? That doesent work.
est. 20€ shipping for 6,300mg part is just stupid^^
Do you have any SOT23-5 3.3V LDOs on hand?
Some of them might be pin to pin compatible.
no I need the original part. The values are different :§
What do you mean the values are different? Something like the MIC5501 (whatever the last digit is for 3.3V) would be a drop in replacement.
pretty sure I have it but in NYC
@Scepterr thanks, ok let me check if I can find something closer.
@Gamer43 I just want to use original parts the output currents from the part above is less but not sure if that will affect the circuit… so I always go with original/similar parts if possible just to be sure.
do you need anything else from the US that you can send to me and I can send to you ?
so far not, but thanks!
Farnell has everything I need so far but I just made a small order and have the most stuff here Just not LM3671. Idont want to pay the expensive shipping again for now. Just for LM3671, the escape6 is the first vesc I know its buildin in that shape. for what are you using this part?
lol repairing ESCapes
thahahaha
I found sth. yey
