Ok so a lot of different advice here and I’ll give mine.
A little bit of background. I’ve been skating for over two decades, been downhilling and racing for over a decade, been electric skating and racing for over two years at the pro level. I’ve taken spills from the first push all the way up to about 60mph.
GEAR! Obviously gear helps, most people know about helmets, but most people really don’t know how important SLIDE GLOVES are. The only other contender are the wrist protectors, but I’ve never used them.
As a downhiller slide gloves are a must, many events don’t even allow you to skate without them. It’s the way you learn it’s the way you fall. Having pads are always a good idea, but you can get away with a lid and a pair of slide gloves if you like to keep gear to a minimum. In my opinion, it’s very much the same for electric. The only difference is that electric has brakes and people never needed to put a puck down to slide. In downhill learning how to slide to slow down comes with learning how to fall with slide gloves in the process.
At slow enough speeds running it out works, at certain speeds a run to a fall on your slide gloves works. If you got knee pads falling on your knees to slide works in conjunction with your slide gloves. If you can fall on your knees without hands like in vert, go for it.
When you’re going fast often times you can get straight up tossed and you don’t have much of a choice and ideally you shoot out with both arms straight out in front of you bracing for impact with your slide gloves kind of like a push up. If you aren’t rocking knee pads you can actually focus on the toes of your shoes and slide the whole way in a true push up stance. More than likely you’re just going to slide on your gloves as your lower body just dangles as you eventually come to a stop. This is the most ideal way to fall BY FAR. Many of my friends including myself have fallen this way at speeds of 45+mph with nothing but some road rash and ripped up jeans. The reason why it’s so ideal is because you are far from slamming your dome on the pavement and if done correctly is way less gnarly on your body.
Tucking and rolling can work too, and I’ve also found myself in that position crashing at 50+mph. Depending on how you’ve been ejected from your board sometimes you don’t have a choice.
Now some people may make claims that this technique puts your wrists in harms way. This may be true to a certain extent, but because of the way the pucks slide it’s actually much better on your wrist than gripping (bare hands, gloves with no pucks). The slide action seems to put more pressure on the whole arm and shoulder rather than jolting impact on mainly the wrist. I have never had wrist issues from this nor have I broken my wrist doing this. Now the only downside is the strength of your arm and depending on how you fall it can put stress on the shoulder in ways you don’t want. I’ll say I’ve been fortunate enough to have never slammed my dome, knock on wood, but I have messed up my leading shoulder (goofy stance, right shoulder). I’ve subluxed it a handful of times due to falling SIDEWAYS and slamming hard with this technique. Now the idea is when you’re cruising at speed is to actually be in a tuck or somewhat in that stance. Because if you fall you’re falling straight forward vs sideways. In addition to falling, it is also more stable to be forward facing in a lower crouched position anyway. The key with all of this is fall forward and not sideways.
Now some people may be wondering about holding their remote with full slide slide gloves. I’m here to say it can be done and that’s what I’ve been doing for years. Group rides, races, etc. I do not ride any boards going over 10mph without slide gloves. You can position the puck to fit your remote and personally I’ve done so that I can hold my remote even while falling and recovering with my remote in hand while I’m still riding. Basically you can bring the board back to you and stand back up as if nothing happened. This is something that’s common in downhill, but I never seen anyone else do this in electric.
I’ll post up some content so you can see it in action. I’m always down answer questions. If anyone is serious about this to know more please let me know, because I also instruct online or in person.
