I’m interested in solutions that could record / display lap times for esk8 short course races.
something like the experience you get at go kart races. though the display doesn’t have to be that epic. could even just be on a phone.
from what I’ve found so far, I think maybe drone racing might have the closest type stuff,
Know any favorite solutions? or what’s the field of possible solutions look like?
Some of the Karting tracks have a built in loop with timing systems. hopefully this covid shit ends and we can get another race booked.
I have a contact at the Fontana speedway but their office is closed through the end of the year. so hopefully next year!. I even have someone that will livestream out events if we are interested.
some tracks rent transponders and some track require you to bring your own.
here is a popular type of transponder on the market… this is a subscription based service that will track multiple users on the track. It probably wont be a solution to your short track racing though because the loop has to be buried. unless you found a way to cover the loop wire and not break it when rolling over it.
The most use indeed mylaps. Problem is that mylaps is running from a server at each karting track and most off the time they are not willing to changes this to it because it can bring trouble when they want to start using their karts again.
The metr already has server repository of records. As long as keep phone on you, and gps is good, you almost have all you need to records laps for multiple folks.
You could have a stationary metr connected to gps that marks the start/finish. Geofence the racers to trigger a record start and stop when a certain distance threshold to the stationary beacon is met.
This idea sounds worse and worse as I write it. But if @rpasichnyk or @WavRX wanted an new headache, I’m here to help.
If this works as they promise on their site. It would be a pretty good and sort of cheap solution. Someone needs to test it and let the rest of us know
