Landyachtz Evo 40 Street Build
I recently got rid of all my boards except for one DIY thane board thinking I am leaving the hobby for good. At least that’s what I told myself. Later I found out the deck of the board I kept was delaminating and its plies fracturing in multiple places. I took that as a cue to rebuild it instead of getting rid of the board like a sane person. :person_facepalming:
The maker of the old deck had gone out of business, and I wanted something slimmer than a typical eskate deck with a dropdown while being able to recycle all the internals from the old board including the 12s4p flatpack. I thought Evo 40 with (@eBoosted) ’s single stack enclosure would work great. It would only take a deck and enclosure swap. I’ve built 4 boards before (putting parts together but not much crafting). This would be easy, or so I thought… What followed was a week of DIY-is-a-disease.
The enclosure arrived with a universal heatsink installed but attached with only caulk and no screws. The heatsink popped out of the enclosure from just handling. I scraped off the caulk and tried to properly mount it with bolts, but the mounting holes were really small and close to the heatsink cutout on the enclosure, so drilling the holes resulted in the enclosure breaking around the holes. I repaired and reinforced the area with JB Weld putty. The heatsink cutout was then sealed and firmly attached with more JB Weld putty.
The wedge shape of the enclosure meant that my 21700 12s4p flatpack did not fit. But I really wanted to use my old SKP pack instead of buying a smaller pack that would fit. I took the battery apart down to the p groups and Tetris’d them into the enclosure by turning some groups 90 degrees. The packs were then soldered together. I repackaged the battery using fresh fishpaper, some hot glue, a new LLT BMS, and shrink wrap. The battery pack basically wedged into the enclosure perfectly and was secured with 3M Dual Lock. Now I appreciate how hazardous battery building can be… That stuff is basically a bomb if you short it. I had a brain fart and soldered the charging cable wrong, excluding the last p group from charging. But was saved by the smart BMS that indicated only 11 groups were charging. I was able to troubleshoot it before too late. :person_facepalming: The charging port was XT60 panel mount.
Using a bigger battery than what the enclosure is designed for meant I had really tight space for the other stuff. A non-Bluetooth BMS is half the size of a Smart BMS with a Bluetooth module, but I didn’t want give up the ability to program and monitor my pack. The BMS was fishpaper’d and Dual Lock’d. My old Stormcore was too big and didn’t fit. I dropped in a MakerX DV6s that has a smaller footprint and is slimmer, which barely fit. The VESC was tacked to the heatsink with a layer of double-sided thermally conductive tape. I put in my old Voyage Minnie with GPS and a Z.mote receiver as well. I strongly prefer dual trigger design.
I wanted to use my GB dual trigger remote, but the receiver did not work when daisy-chained through the Minnie. The GB receiver only seems to work when directly plugged into the VESC’s CANBUS port and not when daisy-chained (or connected through a CAN splitter that I made). If someone knows why this may be or how to work around, let me know (@georgebenett). There’s only one CANBUS port on DV6s, and I needed plug in the Minnie there to double as a Bluetooth module for the VESC so I can program it wirelessly with my phone’s VESC Tool.
I made the already tight space even tighter by cramming in a pair of XT90 panel mounts and some cable extensions to allow swapping the power source to an external battery mid-ride. It’s a system I used with my old board. On a very long ride, I can bring an extra top mount battery and plug it in to the VESC through the XT90 panel mount. Installing the panel mounts takes some patience with Dremel and hand file but not a space issue, normally. But in this build, the space was so tight that I had to be creative, soldering some wires to the connectors in a 90-degree angle. I measured the length of the wires to save space and minimize tight turns that could crimp them.
Unfortunately, the enclosure did not match the deck’s curvature. It must be technically difficult to create an enclosure for an organically shaped deck like Evo. There was about 1/2” gap on the front and the rear and about 1/8” gap on the sides that I had to seal. It was really weird; there was absolutely no gap on certain parts, and a gap on other parts large enough that gravel, not to mention water, could pour in. Using Neoprene (my usual go-to) was going to be difficult due to how huge the gaps were. Instead I used silicone putty, but what I ordered turned out to not cure at all and remain tacky like FlexSeal Power Putty. I wanted something like Sugru that hardens while remaining flexible, but then I would have had to order at least $50 worth of it (that shit’s expensive). Instead, I coated the silicone putty with RTV silicone to remove tackiness while maintaining moldability.
Unfortunately, the added thickness my super thick gasket broke the alignment between the enclosure bolts and the threaded inserts on the deck, particularly in the front and the rear where there is a lot of curvature. I didn’t have the foresight to make the gasket first before drilling the deck and inserting the threaded inserts. After nearly stripping the threaded inserts trying to force in the bolts, I gave up and repositioned the enclosure holes using JB Weld to allow the bolts to line up with the threaded inserts better. This process sucked so much.
In the end, I was able to close up the board successfully and turn on the board. VESC programming was as buggy as ever, but that’s just VESC and and not unique to the build. All in all it was the hardest build I’ve worked on due to the deck and the enclosure combo needing a lot of elbow grease and trying to fit as much electronics as possible into the relatively small and irregularly shaped enclosure. I’m so glad to be done and never hope to open this board up ever again.
Parts transferred over from my old board: SKP 6485s, BN220s with IDEA motor mounts, and MAD 125s. The ground clearance is only 4.5 cm, so I’ll add risers later. I’ll add a handle too probably.
RIP my donor board! Thanks for reading y’all.
Sick rebuild dude! It’s great seeing you keep the diy journey alive, even if it’s for a project as full or profanity as I’m sure this one was :sweat_smile:
Way to push thru the DIY surprises! And thanks for sharing the ups and downs. It helps to know I’m not alone in encountering the “not fun” steps that just have to get done to complete a build. You ended up creating something pretty awesome here.
I love me a good Evo build. Hope you enjoy the heck out of it buddy !!
