83 miles? Damn who beat my record
. Gonna try to beat that soon then
good luck with that. our Legend Derek did 100 miles on one charge
I love where the XT connector is placed!!!
What’s the max safe, theoretically that you can run? 20s?
Can it run 24s like uni’s?
@SammyG for your kart
On the Lonestar? I did 82 on mine with some battery left over. Wanted to see how far I can really go on one charge
Does it have a built in antispark?
24s10p bro?
Is the new firmware on github? (Because it should be. GPL rulez.)
Any plans on merging with the main VESC FW development branch?
yup, with pre charge circuit (with resistors). mom RGB switch, batt level will be reflected in the led
On the led of the switch or on the case of the stormcore?
on the momentary switch, the LED is a RGB
That’s a really cool idea!
If you want this part punished properly–
Top of the list @Arzamenable.
Uphill, Short Track and Long Track racing.
So 100v single. Does it mean we can run 24- 26s on it ?
20S is the max recommended input voltage across the line up.
also Robbie will assist in the abuse!
Vedder, Jeff and Andrew had a play date all together in California this week. I wouldn’t worry about it.
That PCB layout is DENSE. Love the PCB mounted XT90 too!
