Lacroix Jaws 2.0 version power button inop yet VESC shows powered on. (Blue light shows steady) & small square shaped box attached the the bms (battery protection circuit board shows pulsating red…
In addition to my other answer above, the issue you are having looks very much like it could be related to the individual cell fuse that is employed on the lacroix pcb kit.
I have seen fuses like those provide intermittent values exactly like you are describing, you could try bypassing the fuse to see if that helps.
