oOoOO that’s sexy now we just need two people with ocd to wander in here at once and alphabetize it. That’s also how I life hack my house clean, btw.
4 hours to operate, 6 for delicate stuff, 10 once a week to catch up.
aaaaaand its done
Aaaaaaaand now organization has been established and can be followed. That’s how you body a fuckin post. XD
It occurs to me that the conversation here also serves as an entirely different resource for forum noobs. Dope.
@Venom121212 plz add matrix 2 nut issue to the list. (I haven’t actually done the fix on mine yet, they seem to hold? )
Please elaborate
I didn’t expect it to be that easy to find, guess I can add it myself then. Done.
Guess i have to check mine!
It only happens on hangers they leave a mm or 2 gap between hanger pivot and the baseplate pivot point. Manually closing the gap with force was my original solution but I noticed it would loosen up a bit.
My other set of matrix 2s have stayed tight on their own.
ATS12 hangers?
Thanks for the help with this, guys, you’re all excellent and hopefully this list can help some people stay just a little bit safer and richer<3 I’ll be adding some more myself throughout the night while I work.
This is a great resource! I would only add that there should be a forum discussion or picture link to each of the issues. It would serve both as additional research material, and proof of an issue. I’ll try to add some over the weekend.
I agree, was considering changing out all the “solutions” to hyperlinks that lead to more in depth answers.
my last edit got reverted back…wonderful
Is this really an issue? All of mine are perfect. I feel like this definitely needs a link or something, otherwise this could really cause people to not buy tires that are high quality
Another important column to add (not gonna to do it in mobile right this second) is date. So people have an idea of which generation have this problem.
For example, BN has had a few seemingly isolated cases of gear drive wheel adapter holes getting chewed up by the mounting fasteners. But the recent version moved from aluminum to steel (i believe, don’t quote me).
Wouldn’t want to flag products if the problem has been solved/mitigated
Yeah this is my concern too
Yes the new BN gear drives have a steel plate - however, the originals still have ones out there that are fine even with the aluminum
Agreed that the solution should never say “buy a different product”. Maybe “no solution so far”, or we’re just shaming products
Yeah - I would argue that that solution is not even a solution
There are tons of ali tires, many of which are significantly worse than MBS. Also, they aren’t equivalent.
