Gearing changes are as easy as Installing a motor pinion or spur gear. In fact gear drive gives you wider ratio selections in smaller packages than belt drives. Square cut they are 98% efficient and the strongest of all ratio drive systems when steel on steel. Pic below is 8:1 ratio on a 78mm wheel.
Otherwise a great article.
