Why the fuck do i always miss the best deals
Gotta stay tuned. Most of us check forums every 5 seconds
Arenât the axles on the kaly 10mm?
Yup, pretty sure 10mm
Even better. My ultimates are 10mm too so bearings should fit right in.
They have an odd size. I think theyâre imperial cuz 10mm bearings donât fit
Correct. Ultimates are 9.525mm or 3/8" Imperial.
I use the alu bearing adapters and stick with 12mm bearings on most of my boards though
Yay. I was right for once
And the motor gear here is 8mm right? I am hoping my maytech 6374s here will fit right in. The shaft length seems to be perfect at 26mm
Those motors should fit no problem, keyâd 8mm shaft, worst case scenario is you may need to cut some of the end offâŚdunno as never even took them apart or went through the guide.
Anyways sold & thanks
Where that trail? Looks great.
Far far far south from you
Iâm going south anyway. So good to know places from here to my new playground.
@BillGordon
Sorry for asking you to be the pickup truck, i can ask @Flasher instead if you want
