yes charge only.
come to Discord there is a lot of information about BMS. JetFleet
They look very nice! Do you make them in Europe?
I hope you’ve had a chance to look at our new website — we update it regularly.
Our BMS is designed in the EU and manufactured by JLCPCB.
Stable version is out.
Congrats, it looks really cool.
I think you should add the physical dimensions of the case as well, including thickness
Damn! That’s a good price!
Id like to hear what @TheBoardGarage thinks about it
Case is in prototyping stage. But I will add dimensions for pcb. Thanks for pointing it out.
Mounting holes are connected with mouse bites and can be removed if not required. The bare BMS board without mounting holes measures 110 × 32 mm.
This is very useful ![]()
Now it supports multiple thermistors with configurable NTC Beta value and selectable NTC Resistance.
Black Friday Mega Deals are available only while supplies last — ending no later than November 30, 2025, at 11:59 PM CET. Don’t miss out!
hello I am wondering what is the connection between your products and the fungineer thor400 and related 32s bms? are you the designer of both?
Thank you
I designed the original Thor300, but we parted ways after they breached our contract. I am now the designer of all JetFleet products. The JFBMS32 is a heavily improved and optimized version of the VFBMS32.
Yes. Avaspark sells them in US
thanks for your answer, can you expand on the breach of contract?
Picked up one to possibly replace an ennoid, haven’t installed and played with it yet but so far im pretty impressed. I really like that you kept all the components on one side - should make making a heat sink easier.
In your opinion, what is the max charging current it can handle when enclosed vs with your heat sink alu case? What would you recommend to set it up to handle its maximum charging current? I would have bought one if there was one in your store btw but no option to buy. Ill look in the us store but likely make my own.
If you have a simplified cad model i could have to assist with modeling everything up id appreciate it greatly. Otherwise i can take measurements so no worries
I can but in private (DM). I don’t wanna have more drama than what it was.
