I doubt I could’ve made it turn
It weighed more than 1/2 my weight
Im 20 lbs heavier than you oh and taller. But I have no doubt that you can make it turn.
Don’t the g4x that Klaus has weigh like 75 pounds or something?
Working on it make it 100 lbs.
Make it 110… Then it would weigh more than me
Have to find a space to integrate a charger and power supply.
Top mount?
As you irde it without bindings, I don´t want any top mount between your feet.
Can only be something compact, top mount but the the tail.
Hmm… Maybe hanging off the back on top
Excited to see this turn out. At 105lbs, even racing, I don’t necessarily see the point of 225a, I weigh 175 and 80a is plenty for me.
Either way, Im not riding or building it, can’t wait to see what you come up with!
Thanks man! 225Amps is also to grow into as I’m not losing weight anytime soon
On another note, What do you guys think of this new and refined parts list? (Deck will stay the same)
Moestooge 3links (If not then cnc TKP/RKP)
Dual 6369 200kv’s (The @Psychotiller Ones)
12s5p Molicell P42a (Lighter then the 30q and 40t equivalent spec wise pack)
Focbox Unity (Easy and can upgrade later)
Sixshooters from @370HSSV
18/60 Gearing (Speeeeeed)
Safety Gear: (These will not change as I already have them)
Scorpion Exo AT-950 Helmet (Thanks @scrubski for the link)
Rev-it Gloves
Hillbilly Hip Pads (These are a must! Super padded and Comfy)
Vans High Tops
Speed and Strength Padded Jacket
I have to ask how you’re planning to push 225A into dual 6369 motors? They’re rated for less than 80A burst and that’s pushing it. Not to mention Unity can push max 160 total. Or is this suppose to be a 4wd?
dual 80100?
2wd, The Unity will be in there until a high amperage and not overpriced Esc/vesc has become mainstream… Unless their is another vesc that you think I should use? I’ll check out the motors…
I think Unity would probably fare well unless you splurge on a Trampa 6 or something, but even so you would need much bigger than 63xx motors to utilize the potential. If you’re really trying to push almost 10kW in 2wd, you’re gonna need some beeefy parts
Initial bench testing of the the FESC 200A has them pushing 125A continuous and 175 burst without a thermal throttle in sight. Agreed that it seems silly to buy motors that you will just have to replace once you’ve got a better ESC. I’ll bet even the Unity will heat those 6369s up real quick.
What motors do you think I should go with @BluPenguin and @RyEnd? I want at least 190-200kv
I’m using these (not a in a build yet, like I alluded to)
More than 5000W to a motor, you’re going to be looking outside the standard parts bin. Something that is 100mm+ long. I’ve been eying these SSS motors on aliexpress that are all 56xxx and capable of pulling well over 100A. These are uncharted territories for esk8, with only a few people running them and keeping relatively tight lipped about 'em.
Even a 63100 will be maxed out at your specs.
Thanks! I’ll look into those!
