How many times have you cycled that battery? What cells are you using? Are they all the same cells form the same batch? Were they new cells or used cell? When you plug in your charger does [balancing] indicate that its balancing?
No, so once it gets to 4V/cell it will begin to balance and bleed energy from the highest voltage cell. If it gets low when you discharge it then you have a problem but I’d start by letting the BMS do it’s thing
Come cells have a different voltage (in theory you wanna check them all first so this doesn’t happen, but it’s probably okay), so you need to let the BMS try it’s best and go from therr
If a group charges and discharges faster it’s a sign that one of the cells isn’t making full contact so the capacity of the group is lower, in that case you want to extract the group the redo all the welds (I’d use a new piece of nickel and grind the nubs on the cell flat with a Dremel
This is likely the case, if they were all same voltage when you started, you probbaly have a bad weld on one or two of your cells in that pgourp. Recently had the se thing happen
As if it’s seeing all the packs as a 9 p and maybe one has a messed up weld and is charging rapidly bc it’s acting as an 8p?? Or would I experience other issues?
Exactly, if the connection isn’t good enough. That one group could infact be 8p. When I removed my group, I found cold welds on the negative side of one cell. They simply broke loose and my 5p was now a 4p
I think that would be best. I rode my board for a few cycles to make sure it wasn’t a weird balance issue. But this could be dangerous. If for some reason the loose cell starts making connection again you could damage it by over charging or over discharging it, depending on the state of charge of the rest of that group
This is one of the reasons I only build with smart a smart BMS, you can immediately trouble shoot your pack. And not have to wonder its good or not.
