I would just like to say i hate you very much @turdburglar
You stole. My favorite go to username.
Best to match the firmware because you want both vesc basically doing the same stuff and programming is easier. Known bugs are dealt with and you do not want one vesc doing one thing and the other doing something else. Other than that you can use any 4.12 variant with any other unless you can’t and thats esk8. welcome.
There have been a number of very heated discussions on the benefits and the pitfalls of both systems but they both work if you know what you are doing.
Canbus with 4.12.
Never disconnect one vesc from the canbus wiring when powered up. Never. You will blow the can chip and then have to remove it to use your vesc.
Never disconnect the battery from one vesc while the can bus cable is connected because you will blow the can chips in both.
Split ppm with 4.12
One vesc should have all 3 wires to the receiver and 1 with just the signal cable. Thats the one thats not + or - Colours differ. Your receiver will have it marked.
You only want one of the vescs to provide power to the receiver and not both.
There is a potential for a ground loop situation using split ppm but in 2 years I have never experienced it and I only use split.
Never forget about the best (in my opinion) option with is dual PWM (“PPM”)
This is where each ESC has its own wireless receiver and if one fails, it does not bring down the other drivetrain with it.
Do you know any other remote then the mini that works with dual receivers?
I know GT2B does. Not sure which other ones.
I use split ppm on my build, have been for 2 years. I use a GT2b and I just left both of the power wires connected because the receiver specs note that it can take between 5 and 15v. Been working fine.
Not sure about other receivers though I just thought I would say this.
The DIY ones based on nordic radio chip (nRF) can work with multiple receviers as well https://howtomechatronics.com/tutorials/arduino/arduino-wireless-communication-nrf24l01-tutorial/
@ShutterShock think reason you don’t want to hook up 5V and GND from both VESCs is because then you’re hooking them to each other so if the 5V on one is 4.95V and the other is 5.10V relative to some common GND then current will flow (same goes for the GND, if they aren’t hooked to each other normally then they aren’t necessarily the same voltage but now you have them hooked to each other then they are at the same voltage).
Oh I see, so basically the wires may get warm from time to time?
well just could get current flow into the regulator from the output side which it doesn’t expect/isn’t designed for so it’s a little safer I think to just keep one hooked up in case of variance in the regulators leads to some current flow (like you said heating wires or components or burning something up)
Hmm yeah that is possible
Maybe it’s fine maybe not, I can always just cut one wire if I need
I leave the 3 wires on to set up my ppm in the vesc tool because its a pain to swap the things around to get power to the receiver and then once its all calibrated i snip them off. If I were you and using the gt2b I would be running 2 receivers. No drama then even though theres no drama lol
Lol oh yeah I forgot that was the reason I left them connected.
Meh that’s like 10 bucks I don’t need to spend since it’s working
If its not broke don’t fix it. Been using split now for over 2 years on various different things and never had one issue. Did the can bus chips on 2 sets of vescs though because nobody warns you about that shit and realistically for new guys there should be a fucking great warning sticker. My first focboxes literally turned up in a bubble wrap bag with nothing else.
I know for a fact that APS remote doesn’t support it. I should try out the mini
I made a topic for this
Yeah I have no use for can bus. Too risky in our fragile situation and that’s a lot of money lost if it fails.
Mountainboard… Maybe? Not for me though
Oh boy, I didn’t expect it to be used elsewhere. Sorry bro!
my canbus is always failing leaving me on one motor but traction control is so nice i keep going with the canbus…unplug and replug and fixes it.
So, on the note of upgrading (kinda changing the subject a bit, sorry), which motor mount design is best for long term use? I’m still using the Enertion one from way back when they sold parts and alignment is getting off.
I suppose the annoyance of that would depend on how hard it is to open your case haha I need to undo like 6 bolts to pull mine off
