About five months ago, I bought a used DIY electric skateboard. The setup includes an MBoards dual motor ESC, two Flipsky motors (not sure on the exact model, but I believe they’re fairly standard), and a 10S2P MBoards battery.
It had been running smoothly on daily rides until last week, when I suddenly lost all throttle response while accelerating—though braking still worked. I had to push it home. After charging the battery and opening it up, I began testing things. Now, acceleration works only intermittently, while braking continues to function reliably. This issue persists whether one or both motors are connected. When acceleration does work, it only lasts about 10 seconds before cutting out completely. Restarting the board or reconnecting the controller doesn’t restore throttle. Interestingly, if I leave the board off for a few hours, acceleration sometimes returns—temporarily.
It seems like an ESC issue, but I’m not sure how to properly diagnose it or where to begin troubleshooting.
Any guidance or suggestions would be greatly appreciated!
My bet is bad battery. Sags immediately and motors stop. Explains why regen is still working, probably cell under voltage on a pack with a discharge bms
The only wire point I see any issues is one of the green motor wires has worn through the rubber coating, but I taped over it so its not touching anything.
Are there any connections that are commonly loose?
Well good to know now i guess lol. Thanks for the reply.
Is there any risk of ruining another ESC in using the same battery on a new one?
I’ve got a flipsky esc that I was planning on using for another build but is it worth it to plug it all in just to verify that it is an ESC issue? I’m only concerned that something may happen with the new esc.
I have tested the battery with a brand new ESC and a brand new motor. Same issue happens. I believe this narrows the problem down to the battery. I unfortunately don’t have an extra battery. I’ve been considering purchasing a 12s4p to go with my new Flipsky 7070 motors and Flipsky dual FVESC 6.7. Anyone have any recommendations on where to get cheap batteries??
Also, would it be worth getting a new 10s2p battery? I was planning on converting an MBS mountain board into an eboard with the new flipsky things and a 12s4p, but if I get another 10s battery I should be able to hook up my original board and have 2.
Yes! I got a new remote/receiver when I got my new ESC and the same issue happened. I’ve swapped out literally everything except the battery so I’m pretty convinced thats what the issue is.
