Been peaking my head into the FPV world to see if I want to get into drones and what kind/size.
Came across this:
FOCBOX killer?!?!
“Lipo Killer” apparently
Designed and manufactured in Australia
Came across this:
FOCBOX killer?!?!
Damn
- Up to 750,000 eRPM
This is interesting.
However, I have a feeling this either completely lacks regenerative (or thermal) brakes or the brakes are jerky and unsuitable for esk8 use.
The biggest benefit of the VESC™ platform is actually the software and not necessarily the hardware
Only one drama drones dont use regen, I was eyeing off 200 amp efoil escs. Same problem food braking 10Kw best way to destroy my vans.
These do indeed have regen and a control bus likely not canbus but may do the trick.
At $125 DOLLAREDOOS from the australian manufacturer its worth a punt. If nothing else it will be perfect for my single motor scooter build later this year.
It seemed good to me too. Easy to add a heat sink to it as well.
It is designed to have high airflow cooling while running.
I wonder how air blown on mosfets vs attaching a alu heat sink compare. I feel like direct to the mosfets is probably better.
I have upgraded a few 4.12 with heatsinks. they are not designed to run in a sealed enclosure
yup. Enclosed with heatsink just delays the higher heat.
I easily reach 70+ degrees Celsius enclosed. on my street board.
But mid 30’s with my open variant mtb. Same vesc.
I wonder what protocol would be used with these esc?
Im guessing you’d have to eliminate the Flight controller and wire straight from the rx to esc? Or would you use a flight controller and just map the throttle? Interesting for sure, at this size an electric fan would probably fit. I didn’t see anything about a bec tho
14S 180Amp ESC
Imagine 4 of these in a mountainboard
50 Kilowatts here we come.
You’re probably falling for some exaggeration on the cont. Specs but those could be interesting too
Oh Jesus at trampa prices I hope I was wrong with that assumption
Yep like chinese torch lumens. Divide by 10
Or like fl?ipsky 6.6 pus can handle 200 amps for 3 secs before it throttles
