I don’t think think you could fit a 12S4P in here, despite being less cells, unless you did some crafty welding.
Cost:
$59.99 shipped to US, international shipping extra. (quantity above one is less per each) This price may come down if quantities go up high enough. (I’m not trying to make money, just that enclosures for these decks are very hard to find, and I also need some.)
They are approximately 195mm long x 165mm wide (108mm wide battery side and 50mm ESC side) x 75mm tall internally and exactly 257mm (10.12") long x 195mm wide x 84mm tall externally.
They will fit a battery as above and a BMS and a single large ESC like FOCBOX or VESC 4.12 on the side. If you used Super mini Maker-X ESC, then two would probably fit in there with a smaller BMS for a two-wheel drive system.
Using 107mm or 110mm wheels with 25mm of riser is more than enough ground clearance for me, you could probably use smaller wheels or less riser and still be fine.
Really cool little enclosure. Was always curious what it was all about. Crazy you can get 50 cells under a popsicle deck!
Love the offering, but I’m not looking to build another commuter atm.
As these become available they will be made available to the original folks polled above, then new folks. There aren’t very many of them. ETA is “soon” LoLz
