Hello All. I made my first prototype of Vesc case. Target was to create something really functional, water resistant, with great cooling and design. Also to be easy dismount without needs to loose truck screws.I posted this picture on FB and I have nice feedback for it. But one guy ask me if in case that board will crash and rolling, if this case will stay ok. To be honest I was not thinking this way. Because it is my first MTB build, I will be thankful for Your opinion about , how
Thank You. It was really painful proces from mistake to mistake It is Pet-G print with risin on top, than grinded with sand paper and final layer is black mat color. To produce it by plastic molding will be nice, and in big lot not so expensive. Maybe in future. The double roof on it is blocking sun and also it works like diffuser with cooling effect. Bottom is from aluminum. Any recommendations or remarks are welcome!
Thank You. It is still just prototype. Actual fixation it is not final version. As I wrote from bottom is aluminum cooler and double roof on top is sun blocking and cooling system like difusor. Input hole is bigger, output hole is smaller so air flow inside is increasing speed to be able move out from smaller hole. That should have cooling effect. But it was not tested yet. Need to finish my build. Any recommendation are welcome!
I need to think about next priorities:) my dream was to developed own chain drive and own vesc case. Next should be gear drive probably:) problem is that produce injection molded double roof Vesc case is not so easy, so I need analyse how much time I would invest to this topic. I hope that I inspire next people or companies to develop something new, not just two milled deck and plastic frame with screws from top:)
