Depending on the box design, I’m pretty sure other people would love them
I am working on it rn, idk where the holes and cutouts should go. Any suggestions, specs, or dimensions that you feel would be necessary. Obv need cutouts for power, and for phase wires. Built in xt90/xt60 would be pretty slick
I think if I was top mounting it I would really like to have my phase wires and power wire come out the bottom.
I’m going to be using mine in a slightly different unorthodox way. So regardless of what gets designed I probably want to change it and print it myself
Nice! Once you get your design sorted and fitted, could you share the 2d sketch of the cutout for us to adapt to other setups?
I think we talked about it. But if you design and print one, I’ll happily buy one as well
Do it.
@frame @Agressivstreetlamp @Venom121212 @Skunk @Esk8Cali
What connector ports to we want on here? MR60s and XT90? I can also do two different versions (bullets and then MR60), and make both an xt60 and xt90 fit.
Personaly I were to prefer just holes with cable glands. They are more dirt and dust proof and stays with the “universal” feel
That said. I use mr60 and xt60. (But should upgrade to 90 so either is fine)
Ok, makes sense. I could do cable glands, idk. Would you want them to be similar to whats used in the 3ds top mount box?
i prefer bullet then any MR conectors and I don’t care for XT60 or 90 as i use both, but do your thing, we can make do. just keep it as universal as possible
Yeah this is perfect. You can get any kind of cable glands. It this style is great as it keeps universal compatibility on top. And soldering is a skill that can be expected from everyone here I’d say
shorter cable gland would be slightly better, but im just nitpicking
agree. Those glands are phallic
Also, would you want battery cable and phase wires on the same side? That would be preferred if the battery is bottom mounted, but then if top mounted, you would want it the same as the 3ds one.
those are perfect.
as long as u don’t put it side ways, im good
I’d say motor out the back. And battery out the side? That works best for both.
Welp guess we disagree lol
Honestly I can work with anything. But I’d much rather have the battery cable not on the same side as motors
You could also just totally omit t
Holes and just let people still holes themselves. Not exactly rocket science either. Idk if that’s too diY
Bahaha. Also not a fan of battery on the side.
I know you guys don’t care a ton, but I definitely want to get it right.
I will try to figure out some slick way to allow for both.
If the box part is printed I’m sure multiple wire routing option’s wouldn’t be that difficult.
having the battery cable coming out side ways just seems it can easily catch onto something and jank out the connector, im paranoid i know, possibility is too low for this to happen, but i prefer it doesn’t happen at all
