InfinitySink Development Thread - 2020 Community Influenced Universal Heatsink
Hey, still solid effort on your side. A+
This is for focboxes without their case. it’s got the seat for the fets to be thermal interfaced to.
seems less universal. perhaps the mounting holes on the stock base case would be preferred.
yes, I think you are right, in the case is better
They still screw in through the top half of the case and secure through those holes–isn’t that still the same as the base?
right, I guess the outer dimensions change, but the hole pattern would be the same ofc. We can just find OD of the whole unit
stormcore and unity have same hole pattern, but stormcore’s port placement might interfere the screw location for enclosure mounting (if u plan to have enclosure mounting hole on the longer side of the heatsink)
hey man, can you just put an estimated number on the sheet assuming all ur discs are supported. I will do my best to support as much as I can, may have to do 2-3 versions
u got it man, just updated my order
TLDR so apologies if its already been suggested, but I think a ‘wall’ around the fin design would be an advantage to people who want to cut it through an enclosure.
It would give a perfect outline of where to cut and would also give a nice edge to silicone up to all the way around for better sealing.
I’ll go ahead and delete what I was writing. Exactly what I was thinking.
Single stackers will definitely have to cut.
Yeh that’s the plan. I have already made a few heatsinks and they have the wall like ur talking about.
Thanks for the suggestion, I will definitely include that :call_me_hand:t4:
I agree 100%. I’d also make sure the corners have a radius like maybe 2-4mm but definitely not a 90 degree corner because square holes are hard to drill
yessir filets on everything
I will experiment with fillets and chamfers on edges as well…But also wouldn’t you just dremel if it were right angles?
I’d rather not mess up parts that came out of the milling machine nice and sexy.
I think he meant the enclosure.
:astonished::man_facepalming::sweat_smile: that makes sense.
@Tamatoa
Haha yeh I meant the enclosure.
I’m super in for a unity one. Still fill out form?
Lmao @Fosterqc with the 1.5 heatsink
Lol 1-2 wouldn’t compute in the formula
