Anything new?
Dims are different than the v1, and v2, added hole patterns for Spintend and DV6, enclosure mounting holes are tapped now (for those cases where trying to get a wrench in is difficult), oh and I added a chamfer to the fins because it looks nice lol.
I was planning to post specs and a product drawing in the morning, but I can do it now ![]()
So it doesnāt require the mounting plate anymore?
It still uses a mounting plate for all ESCs except the spintend (uses four threaded holes on the heatsink).
Ah i see, i was about about to ask how that would work with escs like the stormcore or unity but the plate image just wasnāt up.
Got it. Sorry, my dorm connection is spotty (I technically have gigabit, but the connection only works like half of the time).
Alrighty! 2022 2023 InfinitySinks are in hand! Several have already sold through messages, but I have a few left. You can purchase at: https://www.machinesuits.com/product-page/infinitysink-2023
Comes with:
- Fin Plate
- Mounting Plate
- Necessary Hardware
Compatible with:
- Stormcore Series
- Focbox Unity
- BKB Xenith
- OG Single Focbox (x2)
- Torqueboards ESC (TB6)(x2)
- MakerX DV6
- Spintend Ubox
Definitely let me know if you have any questions. Thanks everyone!
Woah! Spintend ubox compatibility?? Awesome!
Just bought one. Way better deal than the Bioboards option thatās $110+ with shipping⦠thanks!
Yessir! I made a custom spintend sink for someone like a year ago, only made sense to bring it to V3!
Do you have anything for MakerX G300
I need something for a dual G300 setup on a Fiido scooter.
I donāt unfortunately, not too common. You can pretty easily drill new holes for your ESC. Especially since the ESC just has through holes.
Mine has arrived! Anything specific I need to know to use it with a Spintend ubox? Just screw it on? Thermal paste or pad in between? What are people doinā?
Any advice appreciated ![]()
Honestly, I run mine without thermal paste and I have zero thermal issues. Since the heat isnt being generated all at once, you might not need the extra thermal conductivity and nuisance of thermal paste/pads.
The way i see it, youāre (hopefully) only gonna do it once, may as well give it the best opportunity to do itās job.
In this circumstance I believe thermal paste is more effective than pads. Iād be putting it on for sure.
Iām thermal throttling my ubox when itās barely 40 degrees outside, so Iām really worried about summer riding.
@glyphiks yeah, Iāll probably throw some paste in there, may as well⦠thank you!
at what Wh consumption?
40-50 when riding hard. lots of hills out here in the pnw and we ride fast
this is 2-3 mins after a decent ride
48wh/mile seems on the high side.
yeah, pretty much constant 25-35mph, not to mention im ~230-240lbs with gearā¦
90 motor amps per side, 50 battery per sideā¦
