Posted this on esk8.builders but I figure it would be good to post here too.
Wiring show below via simple photo-shopped file, sorry if its not clean looking this was the easiest way for me to visualize it.
Anyways to the design!
- A123 26650 batteries in a 6s5p config. I am going to get this built by @psychotiller (if its approved) but I just want to make sure my understanding of how battery packs are wired is right.
- DieBieMS - connections via molex and input power from batteries
- Output to female xt60, then goes into a male xt60 to dual female xt60 output
- FocBox male xt60 input
- 10 inch wide hub motor; 24v input, 600W power
- Another xt60 splitter (one for usb charging, the other output for future led lighting)
- Step down converter to dual usb charging ports (input 8-22v, output to 5v)
- Barrel connector
- Boosted board charger (outputs 100-240v, 50-60hz) I figured it would work as boosted uses the same cells.
Any input is appreciated! My few concerns are if the pack can properly power the motor, I calculate it will output about 20V so I hope undervolting a 24V motor is okay.
