Is it the same as this
Wow, that is quite a lot of potting⦠considerably less serviceable. Resolving it all does not sound like a good time.
What remote do you have? I wonder if that is also a change they made when they updated the ESC/remote.
yowza!!
thatās the idea, yeah
Something like this
@Stephensound A bit different. It seemed like there is a plate over the battery packs, under a pile of resin. I think I could get the batteries out if I really needed too. The BMS is just absolutely coated in the stuff. I also donāt know where the problem is! 20200604_090920|500x500
That might confirm my suspicion to be the case. Interesting.
Someone else suggested testing with another device. Urgh duh, I was just thinking Iāve done all that ātestingā but the battery wasnāt under load⦠So I need to go back retest the packs under a load. The only thing I can think of that can go to 36v is my weed whacker? Sounds like a lot of draw, what should I use? Go to a home Depot or something similar and look for 36v light bulbs?
Well shit⦠To top that off I knocked the ESC of the bench, the antena stayed . If it wasnāt dead before it sure is now. Well this project just got a little larger.
How much did you charge for the Custom10s5p? @A13XR3
Where are you located? If youāre anywhere in the bay area California, I can help you
Chicago
Where is that in california
Its not . Iām in Chicago,Illinois. Should I even bother trying to mess with these cells? Or just tear it all out and start new
best case theres a loose connection somewhere in that battery, worstcase its toast. If its potted, just throw it out. not worth the hours pouring into it. build a new one!
PMāed. Nice testing method tho, is that a weed wacker?
Hahahahaha yeah weed whacker! I wired up 3 tail light bulbs at first but burnt out the filament on one
