Important: Xiaoxiang Jiabaida BMS Bluetooth Question
Guys. Quick question. I have this BMS.
I forgot to order the bluetooth module. Do I need it? I mean, I’m going to order right now but can I run without it for now?
Thank you.
Logically speaking yes you do, They have a BT module or a computer cable to plug it into a pc.
If you don’t have either of those you have no way to change the settings on the BMS to the battery that its plugged into.
No way to set failsafes and battery cutoffs, I wouldn’t use it until you get you BT module
