I wish @akhlut want to tap custom bolt pattern to use with my own mounting i’ll definitely run his axles . If not i just make my own axle later. And for baseplate, too late i already bought that from surfrodz minutes ago. Too impulsive/excited i guess
, i’m sure @rey8801 always make excellent stuff
He might, I don’t know if they are already drilled or not.
I’ll wait if he might respond to this, or i’ll dm him later
I like what @Sender did to his Street Carver LaCroix. Proto + SRz Adjust. Plates + Uro = Build of the Year 2018
None ever build with trampa deck?
Haven’t seen one yet. But you and I have the same thing in our minds . I like to try a Trampa Holy Pro with SRz RPK adjustable plates and trucks in the same fashion @Sender did it with his proto
(drop-through if possible and enclosure height permitting
Yeah lets do this haha ,
Yeah, specially with Corona adjusted economy dollars . Deck alone goes for $275… $300 + with shipment.
Crazy, can start with other part cheaper 1st haha which is none, diy never cheaper for me at least, always want more
Precisely. That’s why I’m saving these for the Holy Pro and better times… and of course, this dreamed Street Carver will call it for longer @XTLA 200mm RKP SRz motor plates (black) about to be released in the coming days
Hahaha i just bought tkp black trucks with purple adjustable angle. Be patient with that mount ok, i still keep revising the design .
Wow! I exited now!! . Good thing is, doesn’t matter TKP or RKP, the 200mm SRz hanger is still the same, no?
You mean the mounting? only the press fit is different, the plates will have same design. But this time i think i’ll change something on the plates beside the length. Will update.
Oh yeah, mount design will be the same (aside from that slight change) but now longer, right? As for the Press-Fit you doing them for the 200mm hanger, no?
Is well know that most SfRz hangers lenghts are not the same cross section and press fits varied from one hanger size to another.
Yes for 200
Oooh sounds grrreat !!
Honestly a great modern solution for this would be West Coast Standard ZERO trucks.
I’ll actually be building a Trampa Carver using adjustable baseplates and SR RKP!
Thanks for the share
