I was gunna do this but then it got ran over in a hit & run so I was pretty bummed after not even quite finishing it but I’m putting it back together and still wondering if I’m going to have to do everything all over again but here we go…
This is where it starts getting a bit complex. I had to cast in some anchors for the top battery box in the right spot but also use the same points to attach the stock battery and esc. Lucky thinking about it the opposite way allowed me to mount the anchors to the stock battery enclosure then align the board and fill the holes with epoxy around the anchors.
So I instead of trying to pour thickened epoxy into spots that needed mechanical strength I just stuffed a bunch of chopped strand into the epoxy and overdid it in the center of the board that why it looks like shit.
Didn’t take alot of pictures of the lay up because I was doing it but a layer of fiberglass between the aluminum and carbon fiber. Carbon fiber is conductive and will cause galvanic corrosion if in direct contact with aluminum. I did 4 layers of 22oz per yard unidirectional carbon fiber stem to stern.
I read more thoroughly.
Excellent work. My boss has the same water bottle as you.
The cutouts make everything 75x harder. Very clever filling in the holes and (theoretically and ridiculously?) top mounting!!
A+
Now I shall cover the bottom of mine in sheet rubber, fill in 6 specific holes with epoxy, and bottom mount<3
And you made it sexy. All hips and nips.
