Was about to ship my board…
I cannot get this thing unjammed Gotta buy a new gear anyway…
So much for selling the board.
Check out “gear pullers”
Or battery terminal puller if the inside piece is small enough to fit your shaft
Hit it with the heat man
Yea. Already selling it at a huge discount. Now…even more.
Did. No dice
Find your local autozone. Look on their list of free rental tools. There is something called a pitman arm puller, there is a 3 prong version of it. Use it. Free.
How long? And with what?
Blowtorch. And screwdriver. Didn’t use loctite I think the key just got jammed
One of these?
So last time this happened to me, I used a heat gun for about 5 min and it popped right off.
If you’re just going at it with a flat head and trying to pry it up, try doing that from both sides of the pulley at the same time.
5 min? Ok
Don’t pry too hard, you might rip the entire motor spindle out from the set screws of the motor can instead of getting the pulleys off.
Your safest bet is to use a puller to push the shaft from the gear side.
Figured that was a given lol
I try to be careful of what I say. Next thing you know his board is on fire because he held a blowtorch to a motor for 5 minutes lol
Tried for 5 heat didn’t do it. I’ll get a gear puller
@Underoath888 Not to pry, but why are you taking the board apart if you’re your trying to sell it?
I don’t see how that pulls the gear off tbh
