My man
Moulds are ready to make enclosures if needed.
There are 4 versions.
Single stack, double stack, double stack with double end wire tails for 4x4 and extra double stack extra wide.
Lol I feel like Iām at McDonaldās
Because you probably were at the drive thru when you sent that.
Heck yes, @hummieee
Form filled, money sent!
@BigBen Iāmma be needing one of them fancy boxes, canāt decide which yet, prolly double stack
Is it taller/deeper than the regular double stack as well?
It is yes. Hence extra double, extra wide.
From memory itās around 45mm or so deep including cutout and 170mm wide.
In fact. Thereās one out the back. Iāll photograph it in a moment. Itās a monolithic lump.
Filled out google form and sent payment. Thanks John !
@BigBen will single stack fit 21700 40t batteries ?
The space inside the enclosure is 25mm depth so there should be feasible.
Width of the cutout might be an issue as the enclosure is made to cover this at full height.
Dimensions, pics, and prices would be stellar.
Sounds like for single stack I am better off with 30q. What is the largest configuration of battery pack I can fit using single stack without modification to deck? I tried searching but canāt find quite what I am looking for. What do most people use in their hummie?
With room for esc you can do 10s5p or 12s4p.
If you top mount esc you can do 10s6p / 12s5p
Just a reminder. With the cutout, the double stack is very sleek still. I almost donāt see the point of getting the single stack ![]()
Says the guy with top mounted adjustable base plates on haggys. Lol of course you have clearance
Oh yeah I forgot, dropthruā¦
I have another with dropthru 83mm hummies with 26650 cells. That oneās tighter, and probably is better with a single stack. but I think benās double would work ā the 26650s are pretty fat. With 100+mm wheels, should* be okay. I think.
Thatās a headshot for my wallet. Now I need the double stack enclosure and a new 12s whatever fits p battery for my build.
Why you gotta do this to me man? I have a family.
Will send all paid for this weekend and give u a tracking.
Worth organizing in eu or aU someone get a bunch to them to save shipping
