Hi everyone,
Let me present you my first DIY build which have evolve from his original deck to this drop through and better fit and overall weight.
Here is the 10s3p which fit perfectly the homemade enclosure I usually make from a sheet of steel treated with zinc and bend by hand…
Following the isolation of the enclosure with epm/foam …the esc is actually from another build in the picture that I use with sensorless motor (320kv) another story for another post
I think that every build should be done with some good connection and cable so I always change them either for 14awg or 12awg and some bullet gold connector from 3.5 to 5mm.
Here is the deck I finally bought to fit my first DIY from the first day this thing has been fast as hell and the closer to the ground the better so I manage to find a small drop down with a drop through.
A few vinyl cover for the isolation and protection and there you have it a reliable and cheap enclosure (still need some practice but not that hard with the right plan)
Here is the kind of sheet I start with to make an enclosure
Then time for a break :
Then time for a ride.
So I must say It was a lucky build at least for the way I easily found some componoment to make it and at an affordable way. That first start with my meeting with another riders while riding my three wheeled board : this riders had a backfire and I tried it since then I could not get out of my head the idea of making my own build but budget was short and did not want to rush it either. I looked for second hand part and deck for a while and found some freeboard deck at 50€ and a guys that never had a chance to build his board but bought a diy hubs kit at around 150€. So I was almost good to from around 200€ which blew my mind.
The deck itself have been used for another build 'the red arrow" and I wanted to make this one a more stable board as it really is a fast one. Nevertheless at the en the total cost is more around 350€ with everything you see on the post which is really cheap for such build.
I certainly spent a lot of time making the deck stronger with fiberglass and epoxy and upgrade all cable and connection but still this is my favorite board.
Setup is as follow
-Dual hubs motors 6374 90kv 500w (on steroid)
-Dual FOC esc 50 amp continuous and 120 burst
-90 mm flywheels clone
-Paris truck v2 type 55°
-DIY enclosure (steel zinc treated)
-Drop Through deck (small drop down)
-10s3p samsung 22P (no idea how does one get me to that speed but well) check my youtube channel Eksate for Life
Those are so efficient and powerful I never saw something like those…they can be really scary, climb hills like it was nothing and top up at 55 km/h at full battery (then more like 50 km/h) but the torque is fenomenal.
Let me know what you think about it, enjoy your trip and ride safely
