strangely the ESC does not have any indicator for battery level of my 10S. the remote does not show anything as well.
All I can see is the power button, motor wires, hall sensor wires, and transmitter wire. The hall sensor wires does not fit with my DD motor sensors, https://i.imgur.com/zzN02NM.jpg
upon closer inspection, order of the colors doesn’t even match.
Regarding your problem. If you connect a battery to the esc and pair the remote, the remote itself shows the battery level indicated in the red square.
i was hesitant to buy from anywhere else because the other sites dont mention anything about direct drive motors. my old Meepo ESC did not work properly with my DD so that’s why i had to buy something else. would love to buy the BoundMotor ESC but cant justify the $230 price tag.
anyway, when i connect my remote to the ESC, this is all i see https://i.imgur.com/aEjICXQ.jpg
i am happy i can control slow, med, and fast. everything except seeing the battery status. did i get a defective unit? TBH, when i opened the package, the ESC looks a little beat up. i wonder if i got an used unit
if i press the button once, i see 4 LEDs turn on and turns off about 2 seconds later as seen in this vid https://youtu.be/6YCsOtLhYmw
this is different from the other ESCs and remotes before whereby the LEDs stay lit
oh ok. thanks! i can see how mboards gets such a bad rep now. the ESC and remote came and looked used. next, absolutely no manuals. glad you are able to help out.
