Thanks for the tip, will do ctrl in future logs for multiple data. Yes, 85° fast but the hill good uphill but as we can conclude, heat can be a limitation, good cooling in needed, at moment good heatsink and air flow. Will keep updating, i used hacked firmware from a friend that allow to put more than original values. I tried 150, I will go up 170a, max MOSFETs i think is 195a but that is to much near limit.
For instance the “package current rating” of the FET is for the most part, independent of ambient temperature, and is a function of the internal connections between the silicon die and the plastic package. Exceeding this value does not immediately guarantee that the FET will die, so much as prolonged use above this limit will begin to reduce the lifetime of the device. Failure mechanisms above this limit include but are not limited to wire fusion, thermal degradation of the molding compound, and issues cause by electromigration stresses.
We still would not recommend ever operating these devices over [the package limit] for any long duration of time. In the FET world, that means any current pulse longer than 100ms, above which can basically be considered DC.
I’m glad someone is experimenting and I’m really interested in the long term results, just know that you may end up with a hole in one of those mosfets if you push much past 120A
That’s what I got when I did test against the wall for long time. One phase burned with big hole and little fire, phase cables still intact even after MOSFET steal melt., This is my second unity to make tests
10km/h increase with field weakening 20a in my setup. From 55 to 64 kph flat. Have log, hacked firmware till 160a phase, air cooled, rocking 100%, send log later today and graph
but i have isue with the temp
i’m running 13S8P S22E,
100A motor
100A batterie (knowing that my battery should give 60-70max).
the motor is in a 12" wheel supposed to be 48V1000W
Theses are my log:
power:
Looks about right unfortunately. The controller is good for about 35 motor amps continuous with no cooling in my experience. It will do 100 amps, just not for very long. If you can’t do open air cooling, a powerful fan might work.
The controller will get to 80-85C before it thermal throttles, and it will continue to reduce power so it never goes over 100C. No issue riding it hot… you will just lose power when it overheats.
Just so I 100% understand your right wiring diagram posted, all units were made the exact same the only thing floating out there is the wiring diagram has have different variants, is that correct?
