Quality adhesive hook and loop - preferred for larger items like BMS, ESC if not bolting down w/heatsink
Dual lock/Mushroom tape 250 - preferred for smaller things like remote receiver, Bluetooth modules
Light duty adhesive hook & loop - preferred for battery packs. Enough to keep the pack in place, but easy enough to pull apart you aren’t straining/using unnecessary force on the pack to do so. Either of these work
This is essentially bulk 3m VHB - the thickness is perfect for padding against ESK8 vibration. Preferred to the very thin stuff imo. I’m not a fan of tape for securing ESK8, but if I did/the few times I do, this is my choice.
I often run a very tiny bead of superglue along the edges of the Velcro I put on to resist peeling.
I like this too. I use a line layer of adhesive backed EVA foam over the entire inside and flange.
One thing that i would like to achieve is some decent 3d modelling skills so that i could design a harness for all the other components.
This would involve carefully plotting out the entire guts and then designing a single/multiple pieces to 3d print that would be permanently glued in and would allow me to either clip components in or at least be able to bolt/screw them down.
Not a fan at all of gluing components in. Done it too many times and it fucking sucks for maintenance.
Yeah but its pretty crude and still involves gluing the bms to the angle mount i should have utilised the bolt holes in the bmsto allow it to bolt down
