@kook I belive it’s supposed to go to the 5v so no problem there. I would say to make sure the other wires Are in the correct order it appears your TX isn’t even connected here’s the correct wire orientation-
5V on Vesc to VCC on Module. GND on Vesc to GND on Module. RX on Vesc to TX on Module. TX on Vesc to RX on Module ( yes the TX and RX get swamped)
The cable came with the module from BKBs
Its a 7 pin cable
From bottom to top 5v NC GND NC RX TX NC
and yeah the TX is connected it’s just the angle of the picture.
Should there be LEDs that light up when powered? Transmitting? Receiving?
I only get a short flicker from a red LED when the board is powered OFF or ON
Nothing during normal operation.
I don’t remember off hand. It’s been awhile since the last time used one of these modules. But I think I had the same flicker but no light during operation.
Like I said before, check the wires from the module down to the vesc that there all connected in the orientation I listed above. It could be the maytech vesc has a different uart pinout then other vescs like @deucesdown said.
I just pulled the cable and module. The wiring is correct as far as I can tell
5v GND RX and TX all connected correctly and RX to TX and TX to RX as it should be
The way UART works is an RX must go to a TX and TX to and RX
one signal must come from a transmitter and it goes to a receiver
When telemetry is coming from the ESC it (transmits the signal) TX that signal to the bluetooth, the module (receives the signal) RX.
The opposite occurs when the bluetooth module TX something to the RX of the ESC
@kook Yeah I probably skipped that part…well my bluetooth works as you can see in the pics and I plugged without inverting and even changed a few settings
And you need to set a baudrate of 9600 for UART in BLDC-Tool.
If you have an HM-10 module, the screen print on the back doesn’t say RX and TX it shows “to TX and from RX” so if you connected it that way you’re all good.
In general TX should go into RX and vice versa because one device is transmitting on the line and other side is receiving that signal but nothing to say people can’t label things wrong (perhaps they figure this is easier for average Joe)
I’m currently running, ESC Firmware Version 3.103 and @pookybear has suggested that he had bluetooth issues on that release, I’ve looked and looked and can’t find the file for firmware Version 3.102
I assume that I have to download that file from ACK’s github repository, but for the life of me I cannot locate the correct file.
Can someone please give me a brief walk thru to upload a prior firmware revision.
