Yes
It’s on the very last prompt for App Wizard. Traction Control --> True
–>Write configuration to esc
Ok what will that do?
It will force the two motors to spin the same speed, with a certain amount of allowable difference. Basically it’ll keep you from spinning one wheel on a patch of ice/mud/gravel while the other motor doesn’t spin.
No, absolutely not. Should be between 30 and 42.
Check it with a multimeter.
I think that’s battery percentage. In the Metr App you can verify that the battery configuration to 10s Liion as well. But to be double sure, use a multimeter. But again, I’m pretty sure that’s battery percentage because I charge mine to 100% every time and not 100v
Haha ok. I’m sure it’s percentage. Thank tou
