Hi, so after my e-scooter skateboard I’ve decided I want to build a speedboard, but my current battery is to high, so I was wondering if I need a spot welder or i can use a normal soldering iron to make it
Kindly, someone who has no idea what they are doing.
It’s generally appreciated if people do at least minimal effort making their own research before starting a thread here. Googling “spot welding vs soldering cells” would give you a ton of useful info. In short, you may damage the cells by soldering directly on them so best to avoid it.
I’ve personally soldered a pack and can confirm I blew up at least 3 cells in my house doing so. I threw them in a cast iron pot and slammed the lid just in time for them to off-gas. Just spend the extra money and get a spot welder or pay someone on the thread to do it. Battery builders have the skills and materials to wind up making your pack cheaper than doing it yourself at times.
If you’re going to build less than six batteries, you should buy one from a builder instead. There are many very good ones in various geographic areas.
Also, while building might be a good learning experience, that doesn’t mean you should learn by building a bomb with a soldering iron. So either way, build properly and expect (and budget for) mistakes, or buy one, but do not build using a known bad method
That’s not the learning I meant XD, always contact the forum when in doubt about batteries.
Never solder them, unless the lesson is about thermal runaway
Yeah I mean I’m relatively in favour of getting a welder. You’ll still hit problems, but read the battery builders club thread and be open to redoing and fixing mistakes and it could be a good time
Just know you’re not gonna save money unless you’re making a bunch, and there are real and substantial risks. But to a lot of us it is fun
